fireman32
its been awhile since i've been on the forum, but i have finally started restoring my 89 yj.
the question is on a new fuel tank installation there are two vent tubes on the right side of the tank they both go through a spring loaded check valve similar to a pcv valve all the way to the charcoal canister under the hood. im doing away with this canister so can i just put a valve similar to an axle valve on the tank or is there a better or safer way to vent the tank.
15 gallon metal tank, mechanical fuel pump
thanks for any suggestions
