cornhusker66
The gas gauge quit working so I bought a new one from Quadratech, make that the sending unit-float assembly.
Anyway before I put the gas tank back in I hooked back up to fuel gauge. And what do you know, didnt register anything. I had a gallon of gas or so.
So I pulled sending unit out and hooked it back up. I took the arm and moved it through its range of motion and observed the gas gauge. The gauge did move, however with the float at its highest position the gauge only read half a tank. As I rotated the float the gauge bounced all over. I am assuming I need to order another sending unit? Or new gauge?
This is a new 15 gallon steel tank and sending unit from Quadratech.
Any thoughts? Thanks
