bchcky
so i went to this website http://www.4x4wire.com/jeep/tech/susp/ZJ_swaybar_Qdisco/ and followed their directions for home made disco's rather than paying $100+. went to home depot, got all the needed parts. got under the jeep, started with the driver's side, out in 5 minutes, new tine pin in. went to do the other side, stripped the nut on that side :evil:. now i'm screwed. (no pun intended) i lubed all the nuts and bolts up before i got in there and i still ended up stripping that side. the bolt is a t55 torx fitting and the nut on it is a 3/4". torx side seems to be fine, but i cant get leverage using the torx, so the grunt work has to be done with the nut. any suggestions? i cant get a good turn in at all anymore.
ps - maybe i'll have to use johnny's sawzall (sp?) :wink:
