View from top of rocker gaurd on the TJ. It sticks out as far as the flare. And it goes from wheel well to wheel well.
We actually had to take the flare off and cut it out to make room for the rocker go wheel well to wheel well.
The underside of the rocker. On the TJ it is not flat like the CJ. You have to cut tabs in the rocker to clear the bubbles underneath the TJ tub.
The long arm. We had to cut the stock control arm brackets off of the frame rails.
The TJ just sitting clean.
