M mannygoose New member Mar 1, 2011 #1 1990 xj have a rustys 6.5" lift with a rough country long arm kit. all the arms are to manufatures specs but have a bent coil on the passengers side. Does anyone know why and how to fix it?
TerryMason Administrator Staff member Mar 2, 2011 #2 Manny, I've moved your post to it's own thread, you'll probably get more help this way. As to your problem, are you saying that the coil has a bend in it after you finished installing it, or that it was fine then go bent under use? It sounds to me like your caster is off, and you need to adjust the length of your control arms.
54cj3b New member Mar 2, 2011 #3 are you sure its bent I have seen them come unseated causing it to bow from over flexing something you may want to check before looking for new coils
