southtj
Active member
I've only done one test drive but, man, I think I finally fixed my wobble. This has been going on for about 3 1/2 years as described here.
Short version:
After installing my 2" lift i started getting a wobble at about 50mph and hitting a bump. A new steering stabilizer helped but still happened around 50 and was worse when on the brakes but still only around 50 mph. Sometimes after a tire rotation it was worse. Also if I didn't have both front tires at the exact same pressure (29psi) it would get worse.
I had a Jeep "expert" take a look at everything on the front end and he couldn't find the problem.
It got worse when my MT/Rs starting wearing out and new tires made it better for awhile. Unless the pressure got off etc.
I thought maybe the factory wheels were the problem so replaced them also. Was going to anyway but it was a good excuse.
I tried new adjustable cam bolts a couple of weeks ago but adjusting them all they way forward made it worse so I went all the way backward. Still worse so I put it back in the center. Still having a slight wobble around 50 that got worse when braking.
Replaced the rotors today and ... BAM ... fixed. I hope. Knocking wood, crossing fingers etc.
Moral is, keep tire pressure right and check those rotors.
Short version:
