factory fog lights
trebyelrae
i have a 2004 jeep wrangler and the factory fog lights have quit working and i cant figure out why any suggestions on what it might be??
Thanks
What have you tried the ole hit them a few times or you check the fuses trace wires looking for cracks and what have you
Relay, dirty connection, blown fuse, blown bulbs, burnt wires, burnt connection,loose wire, bad ground, broken wire, bad switch, dead battery,ignition switch not in the on/acc position. Should be one of those.
