extra Dana 44a
cali_92
i pick up a used D44a with disc brakes to swap onto my yj. i dont know if im going to use it or not anymore so let me know if you need it.
ask if you have any questions about the axle etc..
message me , How much? and what does the "a" mean?
Front or rear?
Lowell
It's also c-clipped and uses different lockers and such than a standard 44. And it's a rear axle.
More questions what's c clipped?
I bet it does not have same lug pattern as 97 tl?
the axle has clips to keep the shaft in place. the normal 44 has 4 bolts on the axle flange. it's also 5 on 5".. when did the 44 get clips but the way ?:shock:
The 44a is the only 44 with c-clips and depending on what year determines the bolt pattern. Late 95-98 ZJs have a 5x4.5 bolt pattern just like a YJ,TJ and XJ, the 99 and newer have a 5x5 bolt patten like a JK.
rear d44a (aluminum) off a 96 grand cherokee. 5x4.5 bolt pattern stock 3.73 gears, stock trac-lock. c-clip.
