Day 6
XJReaper
Member
So the engines in and vacuum leak is fixed. I now need to fix a new crack in the exhaust manifold at a weld joint and figure out why there is so much shake at 1.25 rpm.
Sent from my [device_name] using Jeepz.com mobile app
What year is the engine? They make an improved manifold that is less prone to crack.
Check motor mounts. Worn mounts allow your engine to move and over stress the exhaust.
Also make sure your system can move and is for too compressed or in tension.
For the shake is it 1,250 rpm or the throttle position. If it's is the throttle position clean or replace the TPS.
Use only OEM sensors. Others fail early or do not work up front.
JPNinPA
Using Jeepz.com app
JPNinPA
Using Jeepz.com app
I changed the mounts when I put in the motor. I cleaned the tb. But I'm finding differences between motors. The one installed is a 92 motor. The one that came out was a 94. I'm having a hard time finding the coolant temp connector. The plug comes out of the drivers side of block but there is no connecting plug from harness.
The 92 4.0L has two temp sensors. One on the thermo housing that goes to the PCM. And one on the driver side rear that goes to the dash gage.
I can't seem to locate the correct diagram for this.
The factory service manual is your best reference.
Regards,
JPNinPA
Sent using TapTalk
Regards,
JPNinPA
Sent using TapTalk
I had a feeling that one in the back of the block had to do with thermos gauge. I do appreciate all the help and advice.
So the 1250rpm rough running is likely the TPS. A quick check is unplug the TPS and see if the problem stops. Without the TPS you will have other issues so don't run like this.
Only use OEM sensors.
Regards,
JPNinPA
Sent using TapTalk
Another thought but would span more than1250 rpm is your exhaust leak.
The O2 feeds info back to the PCM for air fuel ratios. Once corrected this may go away.
JPNinPA
Using Jeepz.com app
JPNinPA
Using Jeepz.com app
Yesterday I filled the crack on the exhaust manifold with Muffler weld I let it set up today I was going to check it and see if it held or if I have to replace the whole manifold.
Regards,
JPNinPA
Sent using TapTalk
Thank you I will check that out today appreciate all the help.
Regards,
JPNinPA
Sent using TapTalk
Thank you I will check into that today I appreciate all the help
