I got my 32" BFG Mud Terrains yesterday and got them mounted today. Here's a couple pics. I have a couple questions - The guy at the tire shop where I had them mounted/balanced said I needed to regear to 4.10s because running 32s would "slowly burn up the syncros in the transmission". Is this true?? I mean, I imagine it would slightly increase wear running the same gearing on bigger tires due to the fact that the motor will have to turn faster to make the same speed as with the smaller tires, but will this cause my "syncros to burn up" just because of the extra mass?
Also, they rub a little bit on the swaybar, but only under full lock and if the suspension is compressed (i.e., if I'm going really slow so that the springs don't really compress in a corner, it doesn't rub). Is there an easy fix to this? Is it something I should worry about? I mean, I know I could get a bigger lift or wheel spacers, but I dont know that the benefits would be worth it. Is there any other options I dont know about (trying to minimize costs, of course). I'd appreciate some input. I didn't really plan on going bigger than 31's right now, but I couldn't pass up these tires with less than 1k miles (still have the 'nipples') for $350.
Here's the pictures:
P.S. I know I need a 5th tire for a spare .
