absolutemoon
O yea. Started this morn and ran like hammered dog s**t. Sounded rough and sounded like she was missing. Just trying to put as much info out there as possible.
superj said:great!!!! we only have to get one fixed now.
69jeepcj, the idle probably climbed when you sprayed it because the intake was probably leaking at the same point, which could easily be a problem here too so its a good idea you brought it up. pull the intake and exhaust and put a new gasket on when and it will probably help it
You absolutely should. It's a simple 2 wire bypass known as the Nutter-BypassDo I HAVE to bypass my computer when changing to a motorcraft 2100
Gronk said:You absolutely should. It's a simple 2 wire bypass known as the Nutter-Bypass
