Oil Pressure Drop - 82 CJ7
I need cheep. I sold a motorcycle so I only have so much money. I ended up getting some used parts from a 82 CJ. I am almost done with the conversion. It is Pretty simple for the stearing I just need to pick up a bolt I did not know I needed. The thing I am now having a problem with is the Power brake conversion. The peddle is even with the gas peddle now. I have seen some adjustable rods that I am thinking about using. I need to hook up the vaccum and bleed the breakes to see if I need more distance or not.
