Sean81 said:I was looking to purchase an older jeep having owned a tj and a Cherokee i was wanting to get a Cj which is a better choice to build a 5 or 7?
Sean81 said:Any particular things a guy should look for when buying? Which was a better motor the inline 6 or the 304 amc?
Sean81 said:Thanks. I will be looking for one in reasonable shape to start a build.
Sean81 said:I think it will all come down to what I find, if the price is right I would ultimately go with either one. Are there any particular years that had more problems then others?
Matt, were in the same boat. I'm 6'4 and I've got a CJ-5. Next weekend was gonna cut behind my seat for more leg room. It is a little tight getting in and out but I bought the smallest Grant steering wheel I could find and it really helped. [ this kinda helped with the power steering being too sensitive also ] I'm gonna say though, I think if it's a little tougher getting in and out it might be good if you rolled it. [ with a good cage of course ] You'd be less likely to be thrown out.Hi. Really up to you. I think there is pros and cons to both. The cj7 seems to be a lil more road worthy when running big tires/lift also more space inside specially when your 6'6". Off road I personally prefer the cj5 with narrow axles. I seem to go places 7's can't just because of the shorter wheel base. I haven't fully tested this so don't take offense to this cj7 owners. I have owned many cj7's and love them to. I added to my 73cj5 a shackle reverse,put on cj7 springs added power steering which makes it handle pretty good going down the road considering. For more leg room I cut out about 3" of sheet metal behind the front seats. Great upgrade. Couple pics below. Cj'S can be a lot of work to get the right setup no doubt about that but but there's something about those CJ'S. Good luck!
