Chrysler rear axle 9.25
jeepin916
Active member
does any one know how good the chrysler 9.25 rears hold up under high load and stress? stress like about 600 Hp and650 Torque while rock crawling? hehe :?
not a bad axle... i'd say it would handle it... how are you getting those sorts of numbers
also is it possible to use a dana 44 with a passenger side diff on a jeep with a driver side diff? can i swap the transfercase or something? all the parts are commin from a 88 ram charger. i bought it thinkin that it had a dana 44 rear but its got a 9.25 rear and the front is a passenger side diff... thanks snitty
if the Tcase output is on the same side, it will work as long as there is nothing in the way, such as the oil pan or exhaust
1991 4.0 motor and auto transmission for sale
does any know what transes the transfercase from a ram charger might bolt up to?
