southtj
Active member
Ok, I got rid to the wobble problem when touching the brakes at 50mph by replacing the rotors. I guess they were off balance because they weren't warped.
I had also installed some adjustable cam bolts to adjust the caster and was wondering how far to adjust them. The washer has markings around it from 9 o'clock to 3 o'clock. If I go all the way to 3, I get wobble at 50mph and if I go back to 9 I get the same wobble. Which way and how far should I adjust?
