Have an 89 yj with carter carb.. Question is how hard is it to rebuild the carb? I've never really worked on carbs before other then on small engine carbs like law mowers and atv's. I noticed some leaking around the gaskets of my carb today
It's not that difficult......... Do a search on the web for Carter Carbs. You may have some minor issues with tuning afterwards based on how much emissions equipment you have?
The kits normally come with instructions, if you've ever built models as a kid the procedure will be familiar. I run a Carter AFB and the instructions are even simpler than Tamaya's
