Depends on how you wheel. If it's a lazy romp through the forest then ya, the stock axles will handle it. If you like challenging obstacles that require some bounce and copius amounts of skinny pedal, then no. If the latter is your wheelin type, upgrade the front to a D44 and run hardened shafts all the way around, at a minimum.
