Can I leave it in there..
you know, you should really drain that thing :rolleyes:
Make sure you get every last drop of oil that you put in there out, and I mean every last drop if you have to, smear the gears with peanut butter and get a dog to lick it off.
Just make sure you get all that oil that I read you put in there out.
I'll get right on that, boss. :D
So I removed the cover pulled the cap out and put the cover back on with the lubelocker. So far so good.
Atta Boy!
Ya, Lube lockers are great I have had issues with them leaking after draging the rear diff over rocks, but this was over the course of a couple years. I ended up replacing the rear lube locker with RTV, it is a little more plyable in my case where the rear diff cover is a little deformed.
I just got tired of the stuff real fast. Plus the stuff i had bought turned out to not be ok to use if you use an additive and i have limited slip in the rear. But the bottle didn't say that, their website did.
I hate it when they don't give you all the info you need on the product itself. Good job on doing research first. That could have gotten messy
I was looking for something else about it, then I found that out.. Haha
