Sorry to start out this way but I am at wits end without taking it to the $repair guy$
my difficulty lies with the starter 99 4.0 2door asphalt pro stopped starting bout and hour into drive time got "barely used" starter from pop did the same thing put old one back in worked, stopped working thought Grounding prob. removed cleaned then inadvertantly stripped threads put #2 back in works, then stopped 2 days later. transfered old guts to new case worked fine for another two days..... suks but I hafta say that it is currently sitting in the field, I'm not sitting with it so thats a bad thing. anything youve seen like this? bad wire, bad saftey switch on shifter, bad ??
