Still likely a problem with that vacuum switch as you should only have vacuum on one side of the disconnect at a time.
You can always unbolt the disconnect from the axle, slide the shift collar to engaged, and reattach the disconnect upside down. The fork will then hold the shift collar in the engaged position.
