it appears he has a 95, so it's safe to assume he has the larger joint, may be he wants to remove the intermediate shaft?
the axle will swap over easily.
only have to replace the inner pass. side seal.
Some will say that it is a un-needed mod, I personally used to blow 260 joints like crazy, I sourced a set of 95 YJ shafts and I blew the pass intermediate shaft twice.. went with tj shafts, and never had an issue.
