Almosttt there!
Jesse
I'm having a hard time with one bolt on my rear track bar. :cry: Does anyone have any suggestions on how to get it to line up? Is it easier to do a certain side first?
I use a comealong to the frame to pull the axle to come closer so they line up.
That works. Or if you have a couple of buddies around you can get them to push on the body while you put the bolt in. Ive done both ways.
I used a ratchet strap too. The big yellow type truckers use. I also used the winch on my four wheeler once too.
Thank you all for your responses. I'm headed on vacation for a couple days, but when I get back I'll be working on that method. Thank you all again.
