knudsen
I got the light a few days ago. On start up, I get no light, but I get three beeps, a short pause and three more. No OBD codes (Tried key on-off-on-off-on as well as a mactools obdII scanner. As soon as I hit 10 MPH, another longer beep and the light comes on and stays on until key off. I don't think ABS is working after the light comes on, but a few times before the light 10 mph, it ABS'd as I was doing a normal stop on dry pavement.
I went one size up on tires a few months ago, but no problems at all with ABS or anything until now. I did check the pressure and in fact dropped them all by 3 PSI to see if a little smaller diameter would help. I might do the math on the size different and lower them a little more. I just don't know why the newer tires would be OK for 2000 miles or so. I put them on before our first snow storm, which did come early.I've heard larger tires can be a problem, but not to this particular model. I did check fluid.
Rainy day just before it happened, but didn't hit any water hard or anything. Wheel sensors look intact and I reseated the big plug on the pump/CPU thingy.
Dambid Haynes says to take it to the dealer. Doh! :x
Any ideas?
Note: I'm dropping this on a couple of forums, because I haven't found anything on Google or searching the forums I'm posting on. Hope it's not annoying the multi-forum readers.
Any ideas?
