I'm finding more and more problems with my 97. In an earlier thread I talked about the rear end popping noises when taking off. The passenger side wheel seems to be sticking out a little past the flare, while the drivers side is a couple of inches inset. So I started looking around and all the body mounts seem to be intact. I was turning the wheel back and forth and about 3/4 of the way to the right it felt like something was binding through the steering wheel. As I had my dad turning it while I looked underneath I could see nothing out ordinary. When I popped the hood, I noticed that the steering wheel shaft was rubbing against the inner fender well. Could this have to do with the rear end looking shifted over? has the body Shifted? Has anyone ever ran across this? All the body mounts seem to look ok. I did notice when I took the wheels off that the bushing where the rear coil meets the frame is in pretty bad shape?
