6 inch on yj trac bar issue.
smaisano1
I just did a 6 inch suspension lift on my 1995 yj and it seems the track bar is not long enough even with the supplies extensions.. any suggestion?
Do you need a track bar on a yj? Really??? Ha ha ha, if it bothers you, order one of those adjustable ones that is from 4-6"
Welcome to the Z smaisano1. You don't really need track bars on a YJ unless the suspension is really soft or you don't like the handling without them. Try it without the trackbar(s) and see what you think. If you still want the trackbars, I recommend cutting and sleeving the stock trackbars and avoiding the use of brackets.
I've been running a SOA setup without trackbars on my daily driver for several years now.
Which brand lift did you install?
i would've done the same for that price.
you will enjoy your jeep a lot more with no track bars on it
