Hi,
The switch which turns on the light is NOT the vacuum switch at the transfer-case. The transfer-case switch is purely mechanical, while the one for the lamp is electro/mechanical.
The switch is a small blue cylinder (which resembles a typical blue capacitor) and is mounted to the passenger side wall of the engine compartment, just under the coolant reservoir and next to the A/C/Vent/Heater blower motor (near the firewall).
The switch has a single vacuum line and a single electrical connection to it (as it grounds itself when vacuum is present, which illuminates the 4x4 lamp).
If vacuum is reaching the switch when it is supposed to, but the lamp still doesn't work, it is probably just burnt out. :mrgreen:
-Nick :!:
