4WD After Lift
Wranglerman21
I just put a 2.5 inch lift on my 2004 Jeep Wrangler. After installing the lift im having a hard time keeping it in 4LO. Someone told me that alls i have to do is just adjust my 4WD Bracket. Let me know if you can help. thanks!:???:
The 4wd shifter is on a bell crank between the trans. and the body. If the lift is on the suspension, place the shifter on 2HI. Loosen the bolt on the shift rod and adjust the shifter to where it's almost at it's full travel forward on the stick. Tighten the bolt and road test it to check the 4LO operation.
