A point of info on the auto transmissions newer than 85... you only have torque converter slip at low speed, This speed will depend on several things. First is engine size, second is PROGRAMMING. Starting in about 83, Lockup torque converters were becoming standard equipment in EVERY automatic transmission due to EPA Fuel standards Requirements. I had an 84 buick that kept locking and unlocking at 32-34 MPH, BRAND NEW... Had it in to the dealer to take care of this, and transmission guy snuck out of the service bay to hunt me down and talk to me on the sly, told me he couldn't tell me how to do this BUT if you were to go to this one fluid galley in the valve body and open it up one number drill size larger, it wouldn't lock up until the vehicle speed was over 40, and a posted speed of 40 is VERY rare. but they are not allowed to tell customers that. Well you know what I said to do... gas mileage went up, Since the most common speeds not driven on the highway are 25,35, and 45. so there was increased torque at 35 due to the converter doing the work on a small engine, and it had massively improved acceleration below 45... And the 2.8 Loved to do 70-85 on its own to begin with... Any way, All automatics since those days have lockup torque converters due to energy efficiency regulations.
So bear that in mind when changing tire sizes and gear ratios... they can affect your torque converter... If you are strictly off roading, you may want to check into disconnecting the lock up. or find a way to bypass it at will.
Edit: Some of the newer (2000 and up) autos have programmable transmissions, so a programmer MAY be a viable investment for some. this is one of the advantages to giving up some fun of driving a stick.
