I've been doing some research and have heard a bunch of different ideas on fixing rocker arm slop.
i have a small tick so i pulled the valve cover and sure enough there is some slop on my number 1 cylinder rocker. you can spin the push rod and shake the rocker. a lot of people say it could be a failed lifter or just some wear on the rocker. don't really want to go into the engine for the lifter. some say shave the pivot about .20. ummmmm it's not bad, should i just leave it or should i shave the pivot. what do you guys think.
or should i buy a new push rod and rocker and pivot, maybe there is just some wear, i noticed that someone has been in the engine and there are already one maybe two new rockers on there
