3" lift
CruleNIGHTWING
I want to put a 3" suspention lif on a 02 Jeep Grand Cherokee Larado. It's the kind that goes under the coil springs. I was wondering what I will have to do to the alignment after I install it. Any help will be appreciated. I'm dooing it cause it came with 31" tires
Sent from my SM-S820L using Jeepz.com mobile app
you might not have to get an alignment. you will have to put it on and see how the steering is. since your jeep has a solid front axle, usually, just lifting it a few inches will not mess with the alignment
My son just did this to his TJ. When let down, it looked like the camber was way out of wack.....it wasnt. It just needed to settle. Alignment was fine.
Sent from my SM-G935P using Jeepz.com mobile app
