1041135
Normally I'd say easy, you just loosen all the bolts, and jack up your jeep one side at a time and put the new hardware in. The only real problem comes in loosening all the bolts. My 85 was VERY rusty, and it was hard to get all the bolts loose. If you've got air tools then you're fine, if not then get some liquid wrench (like WD 40) and spray all bolts the day before, and use a breaker bar on the end of your socket wrench.
A one inch body lift doesn't require anything like steering shaft lenghtening, and is pretty easy to do. Much easier than putting in a suspension lift.
