TJ Factory Fog Light Cables
I have a 2005 Unlimited that came with factory fog lights. One light was missing, so the dealer removed the other light before I took delivery. Everything else is on the Jeep, relay, fuse, and factory switch on the light stalk. There is a female connector under the front fender on each cable that also connects to the turn signal and marker lights. It is my understanding that this connector is for the factory fog lights. I ordered a Mopar OEM fog light kit from Autotrucktoys.com that was supposed to have everything I needed but the connectors and cabling were different. The cable on the fog light was long enough to reach the connector under the fender but it also had a female connector which was not even the same type of connector. My question for someone with a 2004-2006 LJ or TJ that came with fog lights wired from the factory is.
1. Do your fog lights have a cable that reaches the connector under the fender or?
2. Is there a small cable with the right connectors that goes between the fog light and fender connector?
Thanks for any help with this
