Using Synthetic is the Way to go, using all Synthetic is ah-some, your Engine runs Cooler, you can see this in your engine's Temperature gage, any Synthetic well do, I buy mine at Costco, they sell Mobil, it gets kind of expensive when you do, so I just throw in one can of Synthetic.  But if you choose use all Synthetic, your engine is going to run Cooler, its especially good for use FourWheelers because we run in Four-Low, you want your engine to run Cooler, try it out.  If your running Regular Oil, here's what you should do, change your Oil to Synthetic, run for at least a couple days than change your Oil again, you engine needs to adjust, your all set, enjoy your new Cooler running Engine.
