What do you plan to run off of the aux fuse box?
I would not "jump it" from the current fuse block. Consider runing new wires from the battery including a main fuse in-line. Not sure why you would need a rely prior to a new fuse block unless the new block where only powering circuits that required a "key on" circuit? I that case, yes you would need a main relay or independent relays for each device.
It's not as hard as you think......... You'll still run the new wires from the battery as described, you'll just be adding a mini relay to the postive line. The coil to the relay (A and B) can be enregized by any circuit works during the "key on" position. If you only need a "key on" and not a "acc. on" fuse block, you could use the igintion wire. Regardless, you have several options as the control wire for the new relay.....ie: feed wires to wipers, radio etc.
More thoughts on this ; the car , an '85 olds cutlass 3.8 ltr. RWD needed a pusher fan in front of the condenser to help cool better . Not having a factory electric fan , I added it . Now will just tee in fuses to the 85,86 circuit & 30,87 circuit .
Question ? For every relay added , should each be preceded by a fuse ? I would have to closely read a wiring diagram , but I think the terminal 85 and 86 circuit have fuses , don't remember the 30 & 87 circuit having a fuse , am I right ? Well , in this case , should a secondary power supply being added be wired with a fuse before each relay , 85 & 86 as well as 30 & 87 be added ?
Recently , I added a relay to a car for an electric fan added on . May want to gang a second relay like some factory installations . But I never pre-fused the switched circuit or the power circuit ! Shame , I know . And I know better ! I think I got a job this weekend before the hot weather gets here and the fan really starts kicking in ! Guess I will have to run fuses to each circuit , 85 ,86 & 30,87 ? Don't want this to go wrong , I don't do things like that ! Glad I saw this post , any advice regarding much appreciated ! Thanks in advance , Greg92jeepxj.
Not sure what you're asking? Are talking about a 85 Olds or a XJ? Not certain what circuits 85,86,30 and 87 are? Are you running two fans on one engine/vehicle?
Regardless on the application, each relay needs its own fuse on the supply/positive line. Ideally, the fuse would be 25% larger than the total draw or highest single use device.
