more pics
Will
Do you know were all these wires hook together?
REMEMBER MINE IS A 71 POSTAL DJ, SO I HOPE THIS HELPS.
JUST BEHIND THE ALTERNATOR ON THE DRIVERS SIDE
A LITTLE BIT CLOSER AND LOWER
A CLOSER SHOT OF THE WIRES BEHIND THE ALTERNATOR
WIRES TO THE RELAY
AND THE ONES ON THE FENDER WELL
THE BACK END OF THE FENDER WELL CLOSE TO THE MASTER CYLINDER
FIRE WALL BELOW THE MASTER CYLINDER
HIGHER UP THE FIRE WALL
RIGHT SIDE OF THE MASTER CYLINDER
BETTER PICTURE OF THE COLORS.
MORE PICS ON NEXT COMMENT.
MUDDy
do you know were all these wires hook together?
fire wall behind the carb.
right head light and horn
in front of the carb.
under the carb, between the carb and valve cover.
RIGHT SIDE OF THE JEEP UNDER THE CARB. THIS WIRE COMES FROM...
...THE OTHER SIDE OF THIS CONNECTOR UNDER THE CARB.
THE OTHER WIRES HAVE BEEN CUT. BUT EVERY THING SEEMS TO WORK FINE.
AN OTHER SHOT DIFFERENT ANGLE
AND A FEW EXTRA SHOTS A BIT FARTHER BACK JUST FOR REFERENCE POINTS.
SMALLEST WINDSHIELD WIPERS I EVER SAW IN MY LIFE!
INSIDE WITH TOOLS AND EXTRA PARTS.
LOOKING UP JUST INSIDE THE DOOR
UNDER THE STEERING COLUMN.
UP JUST TO THE LEFT OF THE STEERING COLUMN.
