I´d leave it alone, unless it´s really worn or defective. A new cam will probably only move your peak horsepower into a higher RPM range. Or with a little more lift and duration will mostly mess up your idle and won´t reallly give you any more grunt where you need it, at the lower RPM´s.
Experience tells me trailer towing cams, work best for four wheelers.
