XJ T-Case Wont Stay in 4L
carriss
I Have A 93 XJ auto, I can lock it in 4L and it pops right back out, 4H Works Fine No problems, that being said have a 84 NP-208 with a 27 spline input, if my xj case is bad, or if it destroyed:bomb: later could i swap it in?, or is my stock one have a easy fix? thanks for the input in advance!:D
Sounds like a linkage problem. Can you put it in manually and it stay?
Be sure to remove the linkage off the t case first then shift the t case by hand then take for a short drive.
yep I tried manually shifting way before I started typing on here, I though maybe something commonly internal breaks?
