TwistedCU
Active member
I have seen some longer than stock slip yokes for sale for 96 and earlier XJ's(http://www.rubiconexpress.com/dynamic/mainpage.asp?folderid=234). I thought I heard or read that the newer XJ's already had a longer yoke than the others, which is why I assume the extended ones are listed for the earlier years.
If I by some small miracle have no driveline vibration after installing my 4 1/2" lift, and do not go with a SYE kit, should I be concerned about the possibility of yanking the slip yoke out of the xfer case at full articulation, or is that not as much of an issue with the 97 and later because they have a longer piece?
