I'm getting fluid leaking out and onto my driver side knuckle. I've done some initial searching, and it looks like I need to replace the axle seal that is right next to the carrier. Does that sound right to you guys?
- Should I go ahead and do both seals while I'm there?
- Is there a preferred seal?
- Is there anything else I should replace while I'm working on it?
- My manual says pull the seals out with a pry bar, then insert the new ones with the special Chrysler tool. Is there an easy way to do this without the tool?
