hoobness New member Jul 12, 2005 #1 Will 15x10 with 4" backspace rims fit on a stock 98 TJ - No lift..? If not what needs to be done to make them fit?
Bounty__Hunter Super Moderator Jul 13, 2005 #2 They should, stock rims have more backspacing that that. Depending on what size tires, they'll likely rub your front lower control arms at full lock.
88Wrangles New member Jul 13, 2005 #3 Ya, the wheels should fit. Like Bounty said, the tires might rub though if they are real wide.
