ronpapworth
Tested the milage a couple times. She is getting right around 11 MPG. Sprayed out the throttle body that was pretty gunked up, but can't really see into the air regulator port on the side of the TB. I am assuming the is some sort of wire in there that may need to be cleaned better? Pulled the O2 sensor and it didn't look out of the ordinary. I was going to bench test it, but have never bench tested a 4 wire sensor. And it appears the code puller plug is an OBD 1 as I have a square plug on the right side of the drivers feet. Here are my questions:
1. Should I pull the Air regulator off the TB(star head bolts) and spray it out better?
2. Does anyone know which of the wires I touch the multimeter to on the 4 wire o2 sensor to get a reading when I hit it with a blow torch on the bench?(2 black, a grey and a white)
3. Am I looking at the right plug for the engine codes? I was told a triangular plug is OBD2 on the 95 and the square one is OBD1.
4. Is anyone in the Cincinnati area with an OBD 1 scanner that could hook me up? Because I never take my cars to the dealer and would love for some one to pull the codes on this thing for less than 80.00.
Thanks all.
Thanks all.
