The JKS seems to me to be the best out there. Due to the fact they un hook and re hook very ez. They also come with holders for when you are running disconected. I had Sky Jackers they were on the yj and hooked and un hooked ez but I had to use a nylon tie to hold them up and out of the way during use. L33TJ33P has the JKS's on his so I have seen them 1st hand and they are real nice in every point. Just my 2Cents tug
I also run the ter-flex disco's, I find them easy to use and they came with an extra pin to mount them up out of the way when diconected. With built in zurk fitting servising them is a brease.
Nope,I found them.I didnt look low enough and now I found them.My question is,would it be worth it to get some disconnects???I dont know,because I seem to do fine and have plenty of flex.Would I gain much more flex???An inch or so maybe???
On TJs it is most noticable when you are hitting the rocks that bounce you around but are too small to go slow over. Disconnect and you smooth out. doesn't seam like it would work, but it does.
