I am needing to replace my carrier assembly in my D35. I found one at a friends shop but I am not sure if it will work for my diff. I know there is a break in the ratios where you can not use the ring gear from one to the other. I have a 3.55 and I am wondering how to tell if the carrier I found will work or not. Sadly it is not in a diff so I can not just look at the tag and see if I can use it. Any suggestions?
