Where can I get spedometer gears?
Pretty easy, I did it myself and I hate wiring anything. Let me know if you decide on it and I will let you know the settings that worked for me on the 4 switches.
I mounted mine beneath the dash so I can reach up underneath while driving and calibrate the speedo. It required running about 5 or 6 wires from beneath the dash to the speedo sending unit.
I think I will be going with what you suggested, what all did you need other than the unit? and do you know about how long it took you?
It doesn't take long at all to wire in, the hardest part was determining what the settings are for the 4 switches. If you don't have any luck with the instructions, you can try my settings.
I'd appreciate if I could get your settings.
You can not change speedo gears in a TJ Rubicon.
How do you fix the speedometer when you change tires on a Rubicon then? Also I don't have a rubicon.
