I have an 83 CJ-7 and replaced the front wheel bearings on the driver side. I am running into a problem when reassembling. I cannot get the C clamp or snap ring into the slot on the axle. The hub assembly will not slide on far enough. I can barely see the groove in the axle but not enough is accessible to put the snap ring in. I think the rotor is not sliding onto the spindle far enough. I verified the races are seated properly and have tightened the wheel nuts as tight as I can get them to no avail. Does anyone have any suggestions what might be causing this problem?
