WHAT IS A SPRING OVER!!??
Jizeep
Ok, I have heard so many different people say what a spring over is I don't know what to think...obviously these ppl don't know what they are talking about. ok everybody...WHAT EXACTLY IS A SPRING OVER SUSPENSION LIFT? WHAT DOES IT DO?[addsig]
1040697
A spring over is exacly what it says. The springs rest on the top of the axle instead of being attached to the bottom. It was very complicated at one time and required a lot of welding but now Quadratec has come out with a spring over kit for CJ and some Wranglers. The only problem you may run in to is drive shaft angle but there are also remedies for that. ITS ONLY MONEY[addsig]
1040708
how much do they cost and how much lift do you usually get from a spring over with normal leaf springs?[addsig]
1040756
Warrior products has a spring over conversion kit available. They run about 100 bucks. Then you can get shims to correct drive line angles. There cheap... You get about 3-1/2 to 4 inches of lift.
Good luck.
Eastcoastoffroad[addsig]
