What do y'all think of
I'd be willing to bet the Smittybilt brand winch is just an import with their name on it.
check it out..
I'd lean against it.
I believe it's just another rebadged import.
They're okay for marginal infrequent use, depending on where you wheel. If you wheel out west, or anywhere where a winch failure could mean plumeting hundreds of feet down a mountain, then get a warn. Otherwise the imports may get you by.
Smittybuilt sucks......I've never had any luck with their products. Cheaply built.......should be called Sh**ybuilt!
Little late, but, take it from an "import" owner...........................Bounty's right.........spend the bucks. I will next time.:(
