welding or locker
j salley
With the dana 35 rearend would you consider welding the spider gears or spending money on a locker. And would it hold up or be reliable in a dana 35
I would weld it knowing I'm gunna break it. Save the money for a real diff
Don't waste any time or money on a D35 unless you don't plan on running anything bigger than a 31" tire. Find a 97 and newer 8.25, direct bolt in except for the fact it doesn't work with ABS, 29 spline shafts and close to D44 strength.
