1041663
Howdy,
I have an '82 CJ7. It's been out of commission for about 6 months. Body work mostly. I decided to take it and get an inspection (We have to have annual inspections in Texas) done. The blinkers didn't seem to be working when the headlights were on but they worked when the headlights were off only they were real dim. The running lamps, on the other hand, looked real bright. After a lot of ass scratching, I finally removed the tail lamp covers and watched the filaments in the bulbs. Sure enough, with the headlights on (short filaments) the blinkers were working (long filaments). I don't get it. It looks like, somehow, the wires for the park lamps and the blinkers/brake lights have been swapped. I checked the harnesses. They only go on one way. Nothing has changed! We didn't do any electrical work to the Jeep. In my mind, the short filament should be the brake/turn lamp filament and the long filament should be for the running lights (headlights on). My logic is simple, shorter wire = less resistance = brighter shine for the same voltage. So why would the short filament be working for the running lamps and the blinkers working on the long filament? It doesn't make sense.
Help.
mikell@cvtv.net[addsig]
Howdy,
Help.
