I bought an 85 CJ last year. The vent (hole, whatever the hell it is) in the front of the valve cover (not the oil fill, but the front hole that has a line coming off of it) has a line running to the carb (stock carter BBD trash). The rear hole in the valve cover has a line stuck in it that runs under the battery tray and isn't attached (just basically drains onto the ground). This line coming out of the back hole doesn't fit well and there is oil all over the underside of the hood where it is blowing oil around the fitting (can you say blowby?). Question is, what can I put there to keep the oil from going everywhere. I know it's supposed to be hooked to the carb somewhere, but the jeep runs ok (for having the carter anyway) with it like it is. I'm just tired of cleaning up oil (not to mention the fact that I don't want it starting a fire when it drips down on the manifold). I was going to get a weber for the jeep and figured I'd do an clifford valve cover at the same time and get everything right, but just had a baby and the wife's cut off my jeep funds.... Thanks for the help.
